Thread: What's the most accurate CYA test?
    Default What's the most accurate CYA test?
    After looking at the Best Guess chart and chemgeek's charts, it seems that I should keep my CYA at around 20 so I don't need to have FC above 3 or 4. Because of a slow leak, I do lose CYA over time, so I've been alternating using bleach and trichlor, depending on my CYA level.
    What's the best CYA test out there? I have a Taylor kit with the "little black dot" test, but this seems highly subjective. Also, the results can vary depending on the amount of ambient light, direction of the light, etc. Plus 20ppm is at the very limit of the test's scale. I also bought an AquaChem strip test, but its results are more like rough estimates than anything else.
    Are there any better tests out there for CYA?
    Default Re: What's the most accurate CYA test?
    short of buying a turbidity meter the disappearing dot test is the best one out there. Why do you want to keep your CYA so low. You might find that you get better results keeping it between 30 and 50 ppm and keeping your FC at 3-4 ppm.
    Well, I'm basing the 20ppm on the chart here: http://www.poolforum.com/pf2/showthread.php?t=4236 At 30-50ppm, it looks like I'd need FC of 4-6ppm. I guess that's not a huge difference, but I'd like to keep my chlorine level as low as possible.
    As for the test, are there any specific guidelines on the conditions under which to perform it? Do they assume you're testing outside? Should the beaker be in direct sunlight? I get a big difference in results depending on whether the sun is overhead or is low in the sky. (Light shining through the side of the beaker makes the dot more visible.)
    I don't know... that test just seems goofy to me. I can't believe someone hasn't come up with a better way. The CYA strip test changes color. You'd think that someone could make a dropwise color test for CYA.
    Saint Cloud, FL
    The method I outline in this thread below should help you to be consistent in your CYA testing. Because the test is so subjective it may be tedious to some people, but if you want reliability in your testing you have to be consistent.
    Accuracy of the CYA test will always be debatable, but until you are consistent with the way you test, this will be the closest to accuracy that you can get.
    Pat
    http://www.poolforum.com/pf2/showthread.php?t=1855
    Thanks, Pat. There's some very helpful information on that thread.
    does anyone else have the plastic type tube with the dot in it? i thought that is what everyone has..it's called a taylor C.A. view tube and the range is from 20 to 100. it's what i was given when i bought my pint of test re-agent this summer. seems to work quite well
