Results 1 to 8 of 8
Thread: mustard?...sorry long post
    Default Re: mustard?...sorry long post
    Use the polyquat. It worked for me. Got the tip from one of the threads here, and it worked. Thing is, this year its seems the little buggers won't go away with a shock level of cl, so I tried the polyquat algacide. It did cloud up the water once it was killed, but I used a floc to let it settle to the bottom. Vacummed it to waste, and presto, no more algae since beginning of August! Have had clear water since.
    Sanford, FL
    Polyquat may help - but it really works better as a preventative measure. If it is mustard algae - it will go until you shock to the level appropriate for your CYA level. Then you need to hold it there until the algae dies and the pool clears.
    My understanding is that mustard algae is harder to kill than most - so clorine is really the key.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
  1. What do all of these things do? - long post.
    By Miataguy in forum Pool Equipment & Operations
    Last Post: 08-13-2006, 10:32 PM
  2. Need help with PH and TA (long post, sorry!)
    By jnorris in forum Dealing with Alkalinity and Calcium
    Last Post: 06-15-2006, 11:16 PM
  3. Mustard Algae and Sodium Bromide (Long)
    By tundraSQ in forum Dealing with Algae & Slime
    Last Post: 06-07-2006, 11:15 PM
  4. 1/2 HP Pump will work well for almost any pool... LONG POST
    By John from Florida in forum Pool Equipment & Operations
    Last Post: 05-28-2006, 08:19 PM
  5. How long to hold at 15ppm with mustard algae
    By SoCalBoo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-05-2006, 10:21 AM
