Results 1 to 10 of 16
Thread: Copper Piping Failure
    Default Re: Copper Piping Failure
    It would not hurt to have your water tested for copper and then post the test results (Not just the copper but a full set of results for FC, TC, pH, ALK, Calcium, and CYA...if they can do it an iron test would not hurt either). We can then advise you better on what to do.
    I do have Ben's test kit so I can post those numbers, but I will have to get the pool store to test for the minerals in the water. I will post them tomorrow. It is raining REALLY HARD here!
    I have the readings on the pool, using Ben's PS234 Kit. The pool is 22,000 gallons, inground, vinyl liner.
    FC .5
    CC 0
    TC .5
    pH >6.8 (color was lighter than lightest color0
    Alk 150
    Cal 550
    CYA The dot disappeared as soon as I started pouring water into the tube.
    The heat exhanger in the heater has apparently corroded completely thru. The pool stores says it's due to low pH and has recommended adding pH Up. There is also an automatic chlorinator on the pool.
    Thanks for any help anyone can give me!!
    duraleigh Guest
    Hi, Sherry,
    You have some pretty important water quality issues.....most of which probably center around the use of the inline-chlorinator.
    I would do two things immediately. First, bring your chlorine level up to at least 15ppm and maintain it above ten the rest of the swimming season. Do this with Clorox only. Secondly, get some 20 mule team Borax and get your pH up.....shoot for 7.4.
    You've got a lot of adjustments to make but I would suggest those two right away. There's more to come but by keeping things pretty simple right now I think it will keep you from being overwhelmed.
    Lastly, don't use any more pucks....they're causing most of your problems.
    Thanks, Dave! Before I add the bleach I have another question. . .The pool store tested for metals and said that the copper is at 10 and the iron is at 6.6. They said to add 10 bottles of Omni (sequestoring stuff?!?). They also said not to add chlorine again until the metals were down. When the chlorine was added previously, the pool immediately turned green. I assume that was a reaction to the Omni stuff? Anyway, should the water be tested for metals again or should I go ahead and get the chlorine and pH where they belong. THANK YOU!!
    duraleigh Guest
    Sherry, you've got a multitude of issues with your pool water. Those metal results seem pretty high. I would give serious thought to a drain and refill at this point.
    Adding the sequestrant prior to the chlorine is a good idea (mbar or other metal "specialists" can advise you better than I) but I'm not so sure that the cost and hassle of the sequestrant, all the clorox, borax, then probably having to aerate to get your Alk down will make it more cost-attractive to start with new water.
    You'll have to make the decision but I think, if it were my pool, I'd make a fresh start.....you'll be swimming in a lot less time.
    Dave - I have been thinking the same thing. With the expense of fixing the heater (it was hard piped for the water to go thru the filter/pump then into the heater) and the cost of the chemicals, it may be worth a drain/refill. If I would go that route, would you recommend a complete drain or only partial? We are in Western PA and I don't want the liner to "float" if we do a complete refill and cause more problems. Is there a magic number that is safe to drain to before you destroy your liner?
    Quote Originally Posted by SherrySt
    I would drain and refill...your copper levels are through the roof and so is your iron. Sequesterant will not remove the metals...just make them unreactive with chlorine for a time and then your problems will return unless you keep adding sequesterant. In the long run draining will be your least expensive option! Stop the trichlor...that is what caused the problem in the first place (actually, not keeping tabs on your pH caused the problem with the low pH but your CYA levels are also very high). The plastic sheet method is probably your best bet. If you add chlorine now your water will turn green as the chlorine oxidizes the copper in the water.
