Re: the "timing is everything and i'm an idiot" question
thanks, mas..yes, matter of fact it's exactly in that range. one more question i forgot to ask..tomorrow, while the pool is being worked on ,do you think i should put the cover back on (chlorine will be high, but algae will still be present) or better off to continue to leave off for now?thanks again.
