All HEDP based seqesterants will cause phosphate levels to rise. Don't worry about the phosphates. It's really a scam. Chitosan based clarifiers (like SeaKlear) have some sequestering abiltiy but not as much as a HEDP based product. The Ace product is O-Ace-Sis Metal Out Plus.
I am wrinting that name down now. As far as the metals testing in the water, I never have metals, but I get stains. When the metals have fallen out, or are sequestered, the test will not show metals. So, you would have to get it at the perfect time to have the metals show up on the test - unless you test your fill water - that will show metals (if that is where they are coming from). Metals can get in the water in so many ways - If your pool stains, then there is some metal in there that has to be controlled. I'm sorry, I just don't know where your metals are from, and I don't know where my metals come from either
If I ever figure it out I will post - and I hope you do the same
We can all help each other by posting what works, because every pool is a little different so there are a lot of things to try
). That is about the only thing I can come up with.
. I just can't fiure out why it clouds with the addition of bleach, using up sequestering agent sounds right, but I really don't think I have too much sequestering agent in it, I will have to test it with the sequestering kit I just got, and have been too busy to look at
