Thread: Do SWCGs work in hard water?
    Central Texas
    Default Do SWCGs work in hard water?
    Our water is 430ppm calclium hardness and about 220ppm alkalinity. I can get the alkalinity down to 80ppm but there's nothing I can do about the calcium hardness. Is this a problem for SWCG systems like the Aquarite?
    Thanks,
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
    Mesa, AZ
    Default Re: Do SWCGs work in hard water?
    My pool is at almost 600ppm Calcium (AZ, crazy evaporation and tap water about 450ppm.) My SWCG works well. I do keep my Alkalinity on the low side (about 80) to avoid cloudy water with the high calcium.
    Saint Cloud, FL
    Are you telling us that water softeners are banned? That's the only way you can get low CH. They can work in hard water but the cell could get scaled up reducing its life.
    Pat
    Central Texas
    I don't want to mess with a water softener just for a pool. Not sure how that would work anyway, trying to get 15,000 gallons out of it in a short time.
    My tapwater is 430ppm, just tested the pool and it's up to 500ppm since a complete drain and refill at the first of June this year.
    According to the Aquarite tech support page, places with hard water will require that the cell be cleaned every 3-4 months in a dilution of muriatic acid and water. Sound about right?
    Tom Wood
    Sanford, FL
    Aquarite recommends you clean the cell every three months in the operations manual I just got from my pool builder - I am sure they recommend that for every pool. I doubt that they make a different manual for different areas of the country depending on what they think may be the hardness of a local.
    Don't worry about it - just inspect every 3 months and clean it if necessary.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
  1. hard water
    By nick1628 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-27-2012, 03:04 PM
  2. Salt Chlorinator doesnt work with hard water
    By danspive in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-17-2012, 01:40 PM
  3. Intex sand filter 1500 with Wanda the whale pool cleaner hard to get it to work
    By vickeybear in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-16-2011, 07:25 AM
  4. hard water, need help
    By marshallg in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2006, 09:26 AM
  5. Water is too hard
    By mphare in forum Dealing with Alkalinity and Calcium
    Last Post: 05-01-2006, 04:25 PM
