Thread: Should liquid chlorine smell just like bleach?
    Jakebear is offline Registered+ Thread Analyst Jakebear 0
    Jul 2006
    Pennsylvania
    Default Re: Should liquid chlorine smell just like bleach?
    I've resorted to testing every batch of bleach I buy (I look at the lot number on the bottles).
    Using 1 liter of unchlorinated water (Well --- Rain --- Distilled etc) I use a syringe from the pharmacy to add .1 ml (thats one tenth of a mili-liter) then run a FAS-DPD test ---- By doing this you will know exactly what to expect when you add it to your pool.
    EDIT --- The test result is equal to the percentage of bleach.
    27038 Gallon InGround, Vinyl, DE filter.
