LoL... well I need a filteration right? so zeobrite is just the sand I'd be using if I understood correctlyOriginally Posted by nater
So nope. cannot substitue a BBQ pit for trading in my filteration setup. lol
Yes I am a newbie
Grecian 17'x33' Vinyl liner pool
ZeoBrite filteration
SWG Aqua-rite
Sta-Rite Dura-Glas 1.5hp pump.
SAM Light
21037.5 gallons
Can't you have them plumb for the SWG and then buy it yourself and install it? It will probably be cheaper to get on-line? We paid $1200 for ours with the pool - I hear other people getting it for closer to $800 here on the forum.
It depends on the BBQ - are they running gas line to it? It might be better to have them run the gas line, but then you install the pit yourself - you might save enough money for both.
Or you can do what DH and I did - we are looking at adding the Aqua logic system - figured it will cost $500 plus removing the child fence and installing alarms on the doors/windows. $500=10 times eating out = eating at home for the next two months.
Completed 8/21/06
Spa with spillway
250K BTU gas heater (for spa)
SWCG - Aqua Rite
I'd also go with the SWCG. It makes maintaining the chlorine levels soooo much easier, especially if you need to go away for a few days. I have left mine for up to 12 days and come back to a sparkling clear pool except for a few leaves on the bottom. It will save you more than enough time to pay for itself, and allow more time for grilling when you purchase that.
EricF
33k gallon gunite
Aquarite SWCG
Sand filter
Is the BBQ an add-on that can easily be done after the fact, or is it intergral with the cement and landscape work and just won't be the same if you add it later? If so, I'd get the BBQ BUT spend the little bit extra to have everything set up to install a SWG. ie. electrical, timer, and piping with caps.
If the BBQ is an easy add-on, I'd get the SWG from the start too.
It is this one:Originally Posted by Spensar
I am thinking I'll get something like my parents got, which is a brinkman stainless Steel w/ 3 burners. I can always build around it.
~~ I think I am gonna pull on the SWG and not get this grill.
Thanks!!
Yes I am a newbie
SWG Aqua-rite
SAM Light
21037.5 gallons
did kabobs on one of those this past weekend..awesome bbq..that being said, i'd get the SWG. the money you save on chemicals will soon pay for the bbq and allow you more leisure time to cook with the simplicity of the SWG once you get it setup. zeobrite is only about 85 dollars for 100 lb (equivalent to 200 lb of sand for filteration)..not really expensive when you consider how long it will last you.
Sweet momma, that's some grill! Just run the water under it and it's a pool heater. Where's the steering wheel and beds!!!
I decided to pass on my gas grill that I was going to get b/c I decided to get a SWG ( salt water generator).
Yep I figure I don't want to do the chlorine mixing in the pool.
But its ok. Water softener feel coming out of a pool is better anyway.
....But not to worry, I am getting this grill....
Not as fancy, but what the heck!!!!!!!!!!!!!!
Yes I am a newbie
SWG Aqua-rite
SAM Light
21037.5 gallons
Sweet grill! When's the party?
Sean Assam
e-mail: [email protected] --- www.autopilot.com - www.aquacal.com
