Poolbee,
This is a clear (translucent) body check valve that should remain fairly translucent. It may get a little discolored over time due to the sunlight. If you're seeing it yellow, it may be due to some corrosion of the stainless steel spring within it. Check your water chemistry for low pH (although not likely with a salt system) or high chlorine levels (which can be corrosive over time).
