Thread: DE leaking into pool
    Default Re: DE leaking into pool
    It happens right after the pump comes on in the morning, but stops after the water quits bubbling from the jets. It started doing this daily after my most recent backwashing.
    The pump is 2 hp, the filter is Anthony "Apollo" model # VA 52-2, 52 sq ft.
    Don't know if it is a multi port.
    We add 15 one lb coffee cans which is what is reccommended, after backflushing.
    Backflush procedure is: With pump on, hook up hose to backflush valve, then open valve till water runs clear, then close valve and repeat.
    The seal on the pressure relief valve is broken so it does leak a little. I have a new one coming, so maybe that will fix the problem.
    Jakebear is offline Registered+ Thread Analyst Jakebear 0
    Jul 2006
    Pennsylvania
    I have a Hayward Perflex DE filter --- a small "Puff" of DE after bumping and pump start is normal, and happens because the fingers are not completely coated with the filter media.
    I'm not familiar with the Apollo filter but I think the principals are the same.
    27038 Gallon InGround, Vinyl, DE filter.
    This is way more than a "puff" and it never did it before in the past 6 years we have lived here.
