Results 1 to 10 of 11
Thread: Is shocking necessary?
    Central Alabama
    Default Re: Is shocking necessary?
    Fc 3
    cc < .5
    Tc 3
    alk 80
    cya 30
    ph 7.5
    ch 120
    H2o temp 87
    Richard, I did not necessarily say that the liner was slimey. I just have a feel for how nice and sqeaky clean I like the liner to be and after heavy thunderstorms I have noticed that the liner does not feel just right sometimes. Funny thing is though last week I was having trouble getting it just right and I had a group of 5 people swim for about three hours and it actually improved the situation. I am contributing this to the fact that 3 adults and 2-8 year old kids can move more water around than a 1 horsepower pump could in a week or so. By the way I keep a close eye on the water conditions. Test daily and when I think things are going south I like to test morning and evening.
    IL.
    Something I've notice related to liner "slickness", if your PH creeps up, the liner gets a bit more slippery than usual.
    Quote Originally Posted by chemistrydropout
    Fc 3
    Tc 3
    cya 30
    ph 7.5
    Congratulations on staying ahead of your pool water. It's the best way to keep your pool in perfect condition.
    An FC of 3 with a CYA of 30 is a little on the low side so this should be the minimum FC level you test at the end of the day. Since you may lose up to half the FC amount during exposure to sunlight each day, this would mean you would have to start in the morning (or the previous night) with an FC of about 6 to end up with 3 at the end of the day (unless you use a pool cover or have less than direct and intense sunlight exposure).
    You are correct that having people in the pool can improve the circulation, but I would expect that to mostly affect "corners" or areas away from the inlets where circulation might be poor.
    Richard
    Omaha
    Using the BBB method, this is the first year I have had perfect pool water all summer, even with extremely hot weather. No sign of algae even once! the only issue I had was once my daughter and friends used so much sunblock lotion and it caused the water to turn a bit cloudy, but was back to normal within a day...
    I have not had to shock but once (for the lotion issue only).
    I am so glad I found this group. now I do not know what to with the chemicals I have I no longer need. I have not been able to sell them (cheap) at garage sale.
    Hal
    Mesa, AZ
    With the SWCG, I've haven't had algae in the water for 3.5 years. I did have green algae start growing in the texture of my pebble this year with the CYA at 30 and the FC at 5ppm. I got rid of this algae by removing phosphates and shocking to 25+ppm (not sure which one did the trick, but happy it's gone.) I went for 3 years w/o shocking, but now I shock whenever we're leaving town for a few days. I just dump in enough bleach to get FC up to 25+PPM, then leave town. I have always returned to a perfect pool. This happens 2 or 3 times a summer and that seems to be about right.
    Michigan
    Quote Originally Posted by halds
    Hal
    I'd say don't worry about it and just be content knowing you'll never have to buy all that stuff again.
    Look ahead, not back.
    Why BBB? Because money can't buy happiness, but saving it sure can!
