Results 1 to 10 of 21
Thread: Skimmer socks and algae
    Cool Re: Skimmer socks and algae
    Mom2czars, you're paying way too much. I buy 10 pair of Hanes 'queen size' kneehighs at the grocery store for ~ $5. (BTW I'm not a cross dresser, I use them to add cya via the skimmer )
    Default Re: Skimmer socks and algae
    If you add your bleach through your skimmer, you'll douse those algae spores and kill them. I get about a month out of each skimmer sock.
    Tennessee
    I bought a 5 pack in the spring. I change each day in the morning after I get home from work. I wash out the used one and hang in the sun to dry. Each sock gets four days of sun and drying. The sun kills any thing that may be alive in the sock and it gets reused on day 5. This rotation seems to work well for me.
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    AnnaK, your signature states: 'Used with abandon by three German Shepherd dogs'
    I can see why you need to change your filter sock 2x/day! These guys have a lot of hair. I also see that you have a sand filter. Have your tried adding some DE to the filter to determine if that aides in filtration of particles, too?
    CaryB
    Lehigh Valley, PA
    Quote Originally Posted by ivyleager View Post
    Not yet. It's too late in the season for me to want to go there but it's a plan for next year.
    A.
    Caustik,
    CYA is slow dissolving stuff. It typically will take a week or so to dissolve. I have always just added my CYA through the skimmer. It just dissolves slowly in the filter. I make sure I wait a week before backwashing so I don't just throw it out. Just another option for adding CYA.
    Caustik,
    I will give that a shot. I really am not liking the sweatsocks dangling from the ladder look. I will dump a bunch into the skimmer and see how it goes. Thanks for the input.
    Quote Originally Posted by waste View Post
    Not meaning to thread highjack, but Waste, is that the best way to add the stabilizer? My pool just got filled and they told me to put the cya stuff (granuales) into a white sport sock and dangle it off the side. But, 24 hours later and nothing seems to have dissolved. How much can I put into the skimmer like that without it causing problems with the pump if it even does cause problems. They gave me two containers of the stabilizer to put into the pool.
    Kevin
