Results 1 to 10 of 21
Thread: Skimmer socks and algae
    Tennessee
    Default Re: Skimmer socks and algae
    I bought a 5 pack in the spring. I change each day in the morning after I get home from work. I wash out the used one and hang in the sun to dry. Each sock gets four days of sun and drying. The sun kills any thing that may be alive in the sock and it gets reused on day 5. This rotation seems to work well for me.
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    AnnaK, your signature states: 'Used with abandon by three German Shepherd dogs'
    I can see why you need to change your filter sock 2x/day! These guys have a lot of hair. I also see that you have a sand filter. Have your tried adding some DE to the filter to determine if that aides in filtration of particles, too?
    CaryB
    Lehigh Valley, PA
    Quote Originally Posted by ivyleager View Post
    Not yet. It's too late in the season for me to want to go there but it's a plan for next year.
    A.
    Caustik,
    CYA is slow dissolving stuff. It typically will take a week or so to dissolve. I have always just added my CYA through the skimmer. It just dissolves slowly in the filter. I make sure I wait a week before backwashing so I don't just throw it out. Just another option for adding CYA.
    Caustik,
    I will give that a shot. I really am not liking the sweatsocks dangling from the ladder look. I will dump a bunch into the skimmer and see how it goes. Thanks for the input.
    Talking Re: Skimmer socks and algae
    Caustik, welcome to the forum! Saw this last night but got called away from the pc. As Watermom said, this stuff dissolves sslloowwllyy, so it takes many days to get an accurate reading(or to get out of the sock). PatL34 has a method he came up with for quickly dissolving the cya - he puts it in a fine meshed 'leafrake' on a skimmer pole and places it in front of one of the returns (w/ the pole weighted down to prevent movement). Since I can't leave a few lbs of chem dangled into the pools I work on, I use the kneehighs in the skimmers (I used to just dump it into the pool, but would end up loosing a lot of it when, unknowing, homeowners would vac it out then backwash their filters). There's nothing wrong with slowly! adding it via the skimmer and not backwashing for a week (*however, I had a customer a few years back that 'dumped' ~ 12 lbs in the skimmer all at once - the cya all collected at the first 'elbow' in the line and clogged it solid, nothing would dislodge the stuff, so we had to abandon that line and switch over to the 'reserve line' that we install on every skimmer)
    I'm not trying to scare you out of adding through the skimmer, I've had to do it a few times when I ran out of kneehighs, just make sure the pump is running and that you add it slowly - I always go over to the pump and make sure that I see it comming in. Enough from me for now, I hope you have a great experience with your pool, if you ever need help, feel free to call on the great and knowledgeable folks here!! - Waste
    Quote Originally Posted by waste View Post
    Thanks for the reply Waste. And yeah I added a small bit into the skimmer without the pantyhose to see the effect, since when I tried to clean what was left in the sweatsocks was basically paste I was kind of leary on dumping it all in there. I now have a couple pantyhoses sitting in the skimmer and it is starting to dissolve just over a few hours I can see a difference. The wife didn't need that pair anyhow. Thanks for the info!
