Thread: can U operate pump with cover on?
    Default can U operate pump with cover on?
    I have a 10,600 gallon AG oval pool. I just shocked my pool at dusk (7:30pm). Leaving the pump running for 4-5 more hours. Can I put the solar cover back on during this time, with the pump and filter in operation? Or should I wait until I shut off the pump before putting the solar cover on?
    Indiana.
    Default Re: can U operate pump with cover on?
    You can run with the cover on. I do it almost every day. Your skimmer won't do a great job of catching debris, but the circulation will be fine.
    Honesdale PA
    Welcome to the forum.
    To aid in circulation when you're not interested in skimming, aim the return jet(s) down and away from center.
  1. pool cover pump
    By Barry J in forum Pool Equipment & Operations
    Last Post: 09-29-2011, 06:19 PM
  2. How do I operate my pool??
    By ehc1850 in forum Pool Equipment & Operations
    Last Post: 05-29-2011, 01:52 PM
  3. pump for cover
    By Sean-NJ in forum Pool Equipment & Operations
    Last Post: 11-23-2006, 08:22 PM
  4. Cover pump
    By pool newby in forum Above-Ground Pool Construction & Repair
    Last Post: 10-15-2006, 11:29 PM
  5. Can I operate pool with main drain closed?
    By Dafreak in forum Pool Equipment & Operations
    Last Post: 06-29-2006, 03:05 AM
