Closed Thread
Thread: leave sand in filter?
    Default Re: leave sand in filter?
    i haven't, but like the idea of taking the multiport inside..the added benefit is opportunity when resetting up things in spring to put some filter cleaner in before the season starts and flush clean the sand.
    Thanks for the info! I never would've thought about the pressure gauge!
    24' x 15' x 52" AG Pool
    Hayward S180T Sand Filter/1 HP Pump
    I, too, remove the multiport valve and store it inside. I lube the gasket with teflon lube and seal it in a zip-lock with all the air pressed out. Actually, I do that with all the quick-release gaskets, too.
    I drain the filter and cover it with a contractor grade garbage bag and duct tape it to keep it tight. I ONLY tape on the bag, not the filter.
Closed Thread
  1. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 11:41 PM
  2. how long to leave pump/filter on?
    By rastoma in forum Pool Equipment & Operations
    Last Post: 05-12-2009, 03:55 AM
  3. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  4. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  5. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
