Results 1 to 8 of 8
Thread: pool heating-what i've learned that may help you
    mas985's Avatar
    Pleasanton, CA
    Default Re: pool heating-what i've learned that may help you
    Well, I have solar and I can tell you that without a cover and depending on air temp at night, the most I have lost is about 8 degrees over night and typically it is around 6 degrees. The solar makes up all of that plus some but it does create large swings in pool temp over the day especially when nights are cold. At this point, I just don't want to fuss with a cover but I know that would help.
    Mark
    thanks mark..i will report back tomorrow morning the closing temp tonight based on it being heated up versus temp in the morning. given we are still going to swim in it for the next 3 days, i can't turn the heater off and want to maintain the temp for now, but it will be interesting to see if the heater can maintain that 85 temp with a cold overnight temp (cover on) or if it's going to have lost some ground. i would be very surprised if it's under 80 by tomorrow morning, even with heater cycling and cover on..we'll see!
    well..last night, here's how things worked out. i'm quite happy and thrilled with myself that i invested in a pool cover.
    heated my pool up from a 63 F startup temp to 82. (it took 27 hours so i think that's about a 2/3 degree average rise per hour. i let the heater and pump that point go into my desired 6 hour cycle with the temp on heater being left at 82. the pump/heater were on until 2am with the heater cycling on and off as necessary to maintain 82.
    at 7:30am this morning, i manually started the system (you can't see temp on heater until the heater is powered on). i was initially shocked to see the temp at 63 and thought..ouch...i'm back to square one..seconds later, it jumps to 76..i'm thinking..6 degree heat loss from 2am to 7:30am..average overnight temperature was about 55..6 to 8am this morning it actually dropped to about 42! within one minute of circulation it popped up to 80...i thought ok..now, we're talking! 2 degree overnight loss was awesome..within 1/2 hour it was up to 81...
    so, what this tells me is that my heater while not bringing the temp up in fall by 1 degree per hour as intended, is very easily able to "maintain" the temp once up to optimum temp.
    it also tells me that a solar cover provides a huge benefit..i don't know what the temp drop would have been without it but i have to guess at least 8 degrees versus 2 from what i read.
    the best investment in my "redone system" for cost efficiency will no doubt have been the solar cover.
    i'm now into the cycle and until we decide to close will check the temp each morning and use that as a guage..the key for me will be how much it has to be heated up post the overnight "shutdown" to maintain 82. it would be nice if i can keep it running to end of september. after that point, the daytime airtime is too cold for my kids to have interest. that will also be the key..if it's in the teens post 20+, i know my kids won't want to bother.
    when i first got the pool, i kept it open until mid-october and it got to the point where i was heating it for 12 hours to maintain temp (old heater, no cover) for 1 hour of swimming 3x per week. just isn't worth it in my mind at that point!
    Joliet
    Hi Tenax,
    I haven't owned a pool that long and don't have a gas heater, so please understand that the thoughts I give are just that....thoughts.
    First off...I'm glad to read that things seem like they're going to work out for you. But I have to wonder if a call to the pool store (where you purchased the heater) may be in order. If you give them a call and explain that you've tried the heater out...and while you are happy with the heater by itself...that you made an error in sizing it to your pool and that it doesn't do a sufficient job. Would they be willing to take this (like new, I'm supposing) heater in for an exchange on a larger unit.
    If you could do this while the heater is still new...it may save you some money in gas consumption from month to month.
    In addition to the solar cover AND whichever heater you decide to stick with. Have you given any thought to running a solar heater as well? This way you can supplement the gas heater when the sun is available. Just a few thoughts.
    good luck...and happy swimmin',
    dan
    the heater was bought and shipped freight from the u.s.(less than half the price versus buying it in canada) so that's not an option.
    since i've started this thread, i've obviously picked up more experience. i would never end up running my pool past mid may to end of sept anyhew..the debateable time is the from mid to end of september..
    heater is turning out to be fine for my purposes otherwise. it was able to get up to the optimum temp i want for swimming and beyond in spite of cool nights. (maybe a silly fear, but i had a fear nonetheless that it wouldn't be able to heat the pool up to 82 or potentially 85) it can do it..it's actually better if i can't heat it up reasonably to like 95 as that's where my wife would want it at all the time..82 is good enough for the kids and i, she's fine with 84, 85..even though she says she would like 90+. i said if you want a sauna, pull out the bank book, but that's not the intent of the pool!
    i considered solar heating before i purchased this heater..to totally get away from ngas..it was not feasible unless i put the solar grid on the ground for the square footage required. (something like twice your pool size is a good measure)
    but now that you mention it, i wonder if anyone here uses a combination grid or if that's possible? i do have one roof with a south exposure I believe that's what you want..or is it west?) anyway, i do have a roof that faces south that is about 400 square ft..that's why i didn't consider solar..but if i did that size, it would be enough heat for half the pool and it's on the back side of my yard by the pool so it would be feasible to run pipe...not sure my new pump would have the suction power. i have a 3/4 hp i could theoretically run as well as the main one..hmmm..i have to get more info
