Thread: Heat Pump
    mohawk is offline Registered+ Thread Analyst mohawk 0
    Minneapolis, MN
    Default Heat Pump
    Why do they say that heat pumps are only for in-ground pools? What am I suppose to use for an above ground?
    RavenNS is offline Established User Weir Watcher RavenNS Not to be trusted
    Jul 2006
    Nova Scotia CANADA
    Default Re: Heat Pump
    There are a couple of above ground heat pumps out there...
    I know aqua-pro name & jandy name brand makes one; perhaps additional companies as well...
    http://www.bestbuypoolsupplies.com/heatpumps.html
    http://www.realpooldeals.com/Details.cfm?ProdID=771
    http://www.cheappoolproducts.com/Aqu...2~product.html
    http://www.waterwarehouse.com/products/sku-5616.html
    http://www.zodiacpoolheating.com/products/hp70.asp
    Plus I think some of the smaller ig models are able to be used with ag pools
    Best of luck!
    Country Living in Comal Co., Tx
    Quote Originally Posted by mohawk
    Would heat loss be a reason not to use a heat pump in a AG pool? I don't know, but I'd keep a wet suit around, just to be sure.
    Try these guys:
    http://poolheatpumps.com
    Talk directly to Marcus, and tell him what you want. Highly recommended.
    STS
    19,000 gal IG freeform pool - 14'X40'
    Raised spa with "island" table
    Hayward automation with SWG
    Tristar pumps -circulation, spa, waterfalls
    Hayward Phantom pool cleaner - Love that Phantom!
    Rheem/Raypak Pool Heat pump
    Ben's PS234 kit
    Ft Lauderdale, Fl
    No reason why a heat pump can't be used on an ABG pool.
    Sean Assam
    Minneapolis, MN
    So the reason companies say for in-ground pool use only is because of the size of the pool-water amount? My pool is an above ground round 30' foot. It holds a little over 20,000 gallons. I was interested in the titanium, but now I'm not sure what to do. Also, how would I know which size to buy?
    Minneapolis, MN
    Anyone have an answer to my questions above? I hope to get it all figured out, so we can make a wise choice on heating the pool. Does solar work very well? Denise
    Ft Lauderdale, Fl
    Denise,
    With 20,000 gallons, you'd want to look for at least 100,000 BTUs from the heat pump. BIGGER is BETTER.
    Titanium is the way Heat Pumps are going because of the chemical resistivity of the titanium over the copper heat exchanger.
    A Solar cover will help out immensly!
    Solar panels will work also, but you've got to consider where to place them, with a Southeastern exposure.
    Sean Assam
  1. which heat pump would be best? what should I look for?
    By alisonquilts in forum Pool Equipment & Operations
    Last Post: 08-23-2012, 07:28 PM
  2. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 08:37 PM
  3. What heat pump NOT to buy?
    By marcs in forum Pool Equipment & Operations
    Last Post: 01-28-2007, 04:18 AM
  4. Exactly what is a heat pump?
    By JETTA in forum Pool Equipment & Operations
    Last Post: 06-26-2006, 01:32 AM
