Thread: Heat Pump
    Ft Lauderdale, Fl
    Default Re: Heat Pump
    No reason why a heat pump can't be used on an ABG pool.
    Sean Assam
    mohawk is offline Registered+ Thread Analyst mohawk 0
    Minneapolis, MN
    So the reason companies say for in-ground pool use only is because of the size of the pool-water amount? My pool is an above ground round 30' foot. It holds a little over 20,000 gallons. I was interested in the titanium, but now I'm not sure what to do. Also, how would I know which size to buy?
    Minneapolis, MN
    Anyone have an answer to my questions above? I hope to get it all figured out, so we can make a wise choice on heating the pool. Does solar work very well? Denise
    Ft Lauderdale, Fl
    Denise,
    With 20,000 gallons, you'd want to look for at least 100,000 BTUs from the heat pump. BIGGER is BETTER.
    Titanium is the way Heat Pumps are going because of the chemical resistivity of the titanium over the copper heat exchanger.
    A Solar cover will help out immensly!
    Solar panels will work also, but you've got to consider where to place them, with a Southeastern exposure.
    Sean Assam
