Thread: Pool patch recipe
    Default Pool patch recipe
    I need to patch a couple of worn spots in a plaster pool but am not ready to spend for a whole replaster job. I've been told to use a mix of white portland cement and white marble dust. Does anyone know the correct mix ratio to use? Thanks
    Hal
    Default Re: Pool patch recipe
    Quote Originally Posted by Sumo1 View Post
    Hal
    Still looking for help...
    GutierrezPlastering Guest
    mix 1 portland 2 marble dust if it fits in the wheel barrow; or 1/2 portland and 1 marble dust; mix for 5-10 minutes till you have a wet but somewhat stiff substance
