Results 1 to 10 of 13
Thread: solar heating-check my thinking please.
    Default Re: solar heating-check my thinking please.
    no question the cover was the smartest thing that i did this spring (and the first..even though i didn't have a clue at the start of the season why that is what i did first aside from i knew it was going to be the cheapest item in a long string of goods to get my pool up to snuff) glad i didn't get the heater in spring now...and the cover at end of the process
    winter will include spending time spec'ing out parts and cost for solar goods. 350 bucks is not an extraordinary saving per year, but hey, it's 70 bucks a month, it's 70 bucks a month.
    the key for me is keeping the financial investment practical. if i can keep it at about 1,000 i can see us being here that far in the future..if it was say 2000 dollars, that's 6 years to pay off. my eldest will likely be gone from the house 2 years before it pays for itself, the youngest will be 18 and likely on his way out by then.
    then, we start asking ourselves the question if we want a house with a pool anymore or not..i know , i know..some may shudder at the thought..but it really does become impractical if:
    -my wife will rarely swim (which is the case)
    - i use it even once a day for an hour.
    a hottub at that point would likely be more practical for my wife and i
    Ventura County, California.
    mas985 in post #6, and tphaggerty in post #8 are spot-on.
    Bottom line: The amount of panel area needed is directly related to:
    1) How long you want your swim season to last.
    2) How much daily sun exposure you have where you intend to install the panels AND what you have on your pool through the day.
    3) Are you willing to use a pool cover.
    4) Is your pool subject to any cooling effects from wind.
    5) How fast you want the water temp to rise.
    I think that we can all see that everyone's wants and needs and thus hardware requirements will vary substantially.
    pj
    Has anyone tried using smaller panels that are enclosed with glazing? It seems they would warm the water more and thus be as effective as a larger "less" efficient area.
    Poughquag, New York, USA.
    Quote Originally Posted by msm859
    There is quite a bit about this on the web and even here on the forum. Those panels are designed for heating a small amount of water to a much higher temp than pool panels, but at a much lower volume. To get the same amount of heat into the pool, you would be spending much more money.
    Remember that heat is temp rise * flow rate. At 4 to 10 GPM (which is typical for pool panels) per panel, with 8 panels, I get between 32 and 80 GPM of water at a 2 degree rise. A typical glazed panel will heat 30 to 60 gals of water to about 175 degrees over an hour plus. To get the same heat, you would need a significant number of glazed panels and they are expensive. They are just designed to do a different job. Sort of like comparing a Honda Fit to a semi. Each is more "efficient" at doing what they are supposed to.
