Re: Recieved my Kit - FIRST RESULTS!
mkfmedic
Oh, shoot, I forgot a couple a questions about the testing process. When testing the Cal, and you are adding the drops from Cal 3 bottle, do you stop when the water is clearly blue from the side, or when you can see blue from the top?
The test is done when one additional drop causes no more color change (don't count the last drop) . For example, you add 20 drops of reagent #3 and the color starts to turm purplish, On 21 drops it turns blue-purple, on 22 drops it turns blue, and on 23 drops the color doesn't change anymore. Your endpoint is 22 drops.
And the instructions indicate for those people using Ozone to add two drops of the #3 bottle before the 5 drops from the #2 bottle. Is this if you are only using a ozone system, or does it include those like me who are using both a SWCG & ozone system?
You are referring to step 5 on the instruction inside the lid of the case. It has nothing to do with ozone. (I think you might be confusing an ionizer, which adds metals to the water, with an ozonator.) It is to combat any interferance from metals in the water. The instructions say:
"5. On pools with ionizers, 'mineral tabs', Nature2, Pristine Blue, or copper algaecides, add TWO drops of CAL#3 BEFORE adding CAL#2. Include these drops in your count."
This is to chelate any copper that might be in the water that can interfere with the test. Iron can also cause a similar interferance. Instead of a distinct blue endpoint the color changes to a purplish color and might have purple 'floaties' in the blue solution. By adding a small amount of the third reagent first you tie up the metals and prevent this. I have used up to 6 drops of the third reagent in this manner when testing with excellent results. The color change is much more distinct. Remember to count the drops added before the indicator solution as part of your total!
Thanks and sorry about the goof,
Mike
Hope this helps.
