keep checking the chlorine level and "let it ride"..it'll be fine..i don't believe the pool heater will have any impact in a closed system..i.e. if you're thinking will it help evaporation..if you really want it to go down to a normal level now, then make sure it isn't covered...and along with water evaporation, you'll lose chlorine thanks to the sun, etc. my pool was shocked 8 days ago and i'm still at 10 ppm today..waiting..waiting..to start my new SWG..2 more days maybe? the catch 22 is i leave the cover off my pool to help reduce chlorine level, then i'm going to lose heat and run my heater more..it is septemberif i drain and add water, same deal in that i'll be adding colder water..and i would also lose cya which i don't want to...so, letting it ride
