Re: Multi Port Valve Gasket
Elsie,
He just put a ball valve in the waste line to block that off. You have to manually throw it to block flow through the waste line. I did the same thing. For a long time I had some leakage into the waste line so that is the easy fix...put in a ball valve. Lately when I figured the best way to install a spider gasket, the leak to waste problem is resolved.
