Results 1 to 5 of 5
Thread: Can't raise ph
    Default Can't raise ph
    I can't seem to raise my Ph above the low end of 7.0-7.2
    Over the last 3 days I have added 1 1/2 cups of borax (1/2 cup every 24hours) and the ph has not changed. It seems stuck on this. I do have tri chlor in a "frog" chlorinator but it really does not put any appreciable chlorine in the pool possibly because I only have to run the pump 3 hours to turn over the water 2 1/2 times. I use liquid chlorine and the bleach calc
    The water is and always has been crystal clear
    Ph 7-7.1
    FC 2 -3
    CC 0
    TA 100
    CYA 40
    CH 100
    6600 gal fiberglass pool
    Hayward 300sq ft cartridge filter
    Default Re: Can't raise ph
    Continue adding Borax. It will come up. You don't necessarily have to wait 24 hours between additions. When I am adjusting my ph, I test and add Borax twice a day plenty of times. As long as you let your water circulate long enough for it to mix thoroughly, you can go ahead and retest.
    duraleigh Guest
    I'll bet your pH will come up nicely if you take out the Frog. It's putting out very, very low pH Tri-chlor 24/7 whether the pump is running or not.
    I'm puzzled why you use the Frog and liquid chlorine both?
    Thanks for the reply I will continue to add the borax and am going to try to circulate the water with the frog chlorinator pak (the tri chlor tabs removed} I am puzzled as to how the frog puts chlorine in the pool as it is connected after the filter on the return line
    duraleigh Guest
    I thought the Frog was a floater....not in-line. Sorry I misunderstood your first post.
    Getting that tri-chlor out of your pool will still make a difference in your pH...sometimes a fairly dramatic difference. That coupled with the Borax should have you where you want to be soon. (Although, I would be comfortable with a pH @ 7.0-7.2 as long as it was tested pretty often and it sure sounds like you do.)
  1. Cannot seem to raise Ph
    By D_Case in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-19-2012, 01:45 PM
  2. No CYA - How to raise it?
    By mortimay in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-03-2011, 06:33 PM
  3. Cant seem to raise TA or PH
    By drbob101 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-11-2010, 11:41 PM
  4. Should I raise my TA now?
    By halefmly in forum DPD-FAS based testing
    Last Post: 02-12-2007, 05:07 AM
  5. Can't raise PH
    By aguaguy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-26-2006, 10:18 PM
