Results 1 to 10 of 13
Thread: Drain & Fill Question
    Jakebear is offline Registered+ Thread Analyst Jakebear 0
    Jul 2006
    Pennsylvania
    Default Re: Drain & Fill Question
    Here is the answer to your prayers.
    Silage Tube ---- Yep, those big tubes that farmers blow cattle feed into for storage and feeding in the winter. You can buy them at most farm supply stores and they are available in various sizes -- 6, 8, 10, feet diameter and bigger they come in up to 8mil thick --- the way I figure it you could close one end --- lay it across the water of your pool and fill it with water. A 6' diameter 20' long tube should hold 565 cubic feet (3.1416 X Radius Squared X Length X 7.5 gal per cubic foot) which is equal to 4237 gallons ).
    Water seeks its own level so the excess will go out the overflow or over the edge if you get a tanker to fill it with a big hose.
    27038 Gallon InGround, Vinyl, DE filter.
