Results 1 to 10 of 13
Thread: Drain & Fill Question
    Default Re: Drain & Fill Question
    I wanted to get to the REAL point: with excessively high CYA you cannot try to drain a little, then add a little to be effective.
    OK, I got it. The main takeaway point I wanted to make was that if you want to do significant dilution, especially more than 50% (if you have very high CYA over 100, for example), then using a sheet or silage tube uses much less water and is much more efficient (for water usage, though obviously takes more effort). I just thought the 100 gallons 100 times (to get 10,000 gallons) would be misleading and let people think they didn't need to use the sheet method to be efficient. However, for just a 50% dilution, doing it continuously is certainly a reasonable option and is "close enough" to help get the CYA lowered (going from 100 to 61 isn't that far off from the goal of 50). If the goal was to go from 100 ppm to 25 ppm, then a continuous drain and refill of 75% of the pool water only gets you to 47 ppm. I'm sorry I was so picky.
    Personally in my own pool, I dilute it each winter with winter rains filling in and overflowing (to a sewer drain) and that's a continuous method, but since I'm not paying for the water I don't care that it's not efficient (our water is very expensive where I live and is sometimes under restriction). I do this to continually refresh the water each season. I do need to add some more calcium, bicarbonate, and CYA when I open up in the spring. Now that I'm not using extra chemicals (non-chlorine shock, clarifier, polyquat algicide, de-foamers, etc.), this refreshing of the water probably isn't necessary.
    Richard
  1. Fill with only 1 foot of water and don't fill for 24-48 hours?
    By Jacob99 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-26-2012, 07:00 PM
  2. Drain & Fill for Algae?
    By BananaE29 in forum Dealing with Algae & Slime
    Last Post: 08-08-2011, 02:16 PM
  3. Newbie question - would we be better off to drain and start over?
    By RockheadedMama in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-06-2011, 10:31 AM
  4. Main Drain Question
    By columbusdan in forum Pool Equipment & Operations
    Last Post: 06-05-2010, 10:33 AM
  5. Question on bottom drain and pop ups
    By slater1182 in forum Pool Equipment & Operations
    Last Post: 05-20-2006, 11:33 PM
