Thread: Best way to clean the Pool Pump
    Default Re: Best way to clean the Pool Pump
    i don't see any other way you could it thorougly ( i mean, spraying water into it likely won't work if the pressure of water flowing through didn't...i guess you could try using long handled pliars to pull stuff out if you didn't think there was a lot and were shy about taking the pump apart but yeah..like cracking an egg shell and see what's inside..it really shouldn't have more than small bits of leaves though..they should be shredded small enough to go up to the filter and out when you backwash or send to waste..is your basket damaged?
    Honesdale PA
    Sure looks like that band allows the pump chamber to come apart. Slick, try it. I'd bet the parts that the band holds together have a large O-ring for sealing. Most that would happen is the O-ring would have to be replaced. Also get a tube of silicone grease for the ring when you put it back together. And like Tenax said, you should not be getting big stuff to this point in the syetem.
    i've had mine apart..it's no biggie..just be careful when you put it back together..over tightening that band can crack the housing if you get too excited
