You can blow out the returns by disconnecting the unions to your filter, move the filter back to get access and then blow it out through there. I usually have all the returns bubbling away, insert the plugs, when there all plugged go back and remove one plug, let more air bubble out replug and repeat with the other remaining returns. Don't forget the pool sweep line if you have one.
