Algae problem at my workplace..but not in a swimming pool!!
I work in an aluminum extrusion plant and we have an anodizing line, which is a chemical/water based line that etches, colors then seals the aluminum extrusion and is used mainly in architectual applications such as window/door systems in high rise buildings, schools, mini malls and pretty much anything non-residential.
We have been looking for ways to increase production through this line and our chemical vendor has supplied us with an additive to decrease the time a work rail spends in the anodizing tank which is filled with water and sulfuric acid. Our tanks our 8 feet deep and 40 feet long.
The additive works very well, but is extremely expensive so we quit using it for awhile, but once again due to production requirements we started using it again.
Every time we use this additive (I'm actually not sure what it is) our rinse tanks, which some use city water, and one uses DI water grows algae pretty bad and pretty quickly. Our chemical vendor has supplied us with a thing they call a "bug zapper." It's apparently an electrical probe that emits electricity to the tank in effect "zapping" the algae. We are trying them out and they seem to be working okay, but at the tune of $7000 each they aren't cheap.
I asked if we could use chlorine to fight the algae in these tanks, but found out the chlorine would have a negative effect on our seal and color tanks so that is not an option.
Has anyone heard of these "bug zappers" and do they make something like this for a swimming pools?
