If you are using the Aqua cover you don't need to lower your water level.....
But I thought that if there's water in the skimmer, when it freezes you're SOL. Can you use a gizmo AND a skimmer cover? I've only ever used gizmos/draining method. If using the cover in addition is a good thing, I'll def get a set.
