my bad..regardless, a lot of the stuff should still apply but i'm sure there are differences!
Tracey,
The aqualuminator - just disconnect the cap, wires, take the bulb out, now you should be able to look straight through it into your pool - if that's it, you're done with that part. You should only have the thin flange left showing inside the pool.
Of course, drain your pool below the aqua lum return first or else you get wet.
I only drain to below the return, no further, rain and snow just fills it back up again anyways.
Keep any shutoff valves open.
Disconnect hoses from pool, take out drain plugs from pump and filter, place BOTH plugs in your basket inside the pump for storage.
Unbolt the multiport valve from filter, any gaskets and bolts that come off with that should also go into pump strainer. Close pump strainer lid to safeguard loose components.
Take everything you've just removed to a frost free location - Garage/basement.
Place a large garbage bag over the filter since the top is now open, bungee it on, but let the drain plug opening show beneath the bungee so it can continue to drain without ending up in the bag's folds.
Leave filter as is (leave sand inside it) and don't try to move it, it won't get damaged through freezing, but will get damaged through moving it.
You should now have a pool with a water level below the return, no light head in the return opening, nothing connected to either hose connections outside of pool, with a filter casing only standing beside the pool - covered.
Everything else should be inside.
You can cover the pool if you want to, I don't bother, I have no leaves to speak of and found it less strain on my pool structure to forego the cover completely (high winds). It just freezes solid for the winter and is less work to open come spring.
I keep my solar cover on the roller, but roll it up real slow so water doesn't collect between the layers (it still does to some degree) so every day or so when I pass it I give it half a turn in the roll up direction, after a week or two of that, any remnants of h2o between layers will have rolled through it and out the end. I bungee that with 4 bungees after wrapping it in one of those white protective sheets.
All pool equip - poles etc come in the garage for the winter.
Any drop in steps/weights also have to come out.
hey matt,
Niiiice. Thank you. just a few ?'s
What do you mean the top of the filter will be open? Is the top taken off and stored inside?
2nd......the exposed hole (the return and skimmer) should they be capped off say w/ duck tape or something to keep critters out of the pool?
3rd.... the sand in the filter is only 3 months used, and I would like to leave it in there as you suggest, but won't it mold and grow "stuff"? I mean for 20 to 30 bucks, what's emptying it all out and then moving the pump AND filter to a garage????
I didn't know if we should close off openings to pool interior for extra cleanliness ........and to keep cold mice out during winter months.
I do intend to cover my pool w/ a top grade winter cover cause I have ALOT of trees around. (my photo is in above gr. pool gallery if you d like to see)
Anywho.........thanks so far. My pool dealer provided me w/ a top notch ester williams pool, however post sale cust. service sucks. So, I figured I'd turn to my favorite pool experts who will better serve me any way. You all have not failed me yet.
THANKS AGAIN
Hi Tracey,
Once you remove the Multiport valve (unbolt the ring of about 8 bolts on the neck), there will be a 6" hole looking down onto the top of your sand - this is why I cover mine with a Garbage bag. You can put the handle on "winterize", whick opens the valves inside so water and air can freely expand as needed, however, since it is a relatively necessary mechanical component, I feel it is better to store it inside away from the harsh elements.
I don't cap any holes into the pool, I actually lean a board against the side of the pool on an angle so any water that needs to run out can travel down the board and a bit away from the side of the pool - no mouse will ever be able to scale those pool walls - no grip. I haven't had any critters get into the pool - besides, they look for warm places, the pool will not be warm since it is outside.
Don't do anything with the sand, you've backwashed it for a long period of time while draining, so prety much all gook is gone from it, mine's always just as clean come spring time as when i closed in fall. Emptying it can risk breaking laterals, then you have to repair those etc...
Your a life saver matt....thanks
May hit you up w/ more ? s later. Going to "pool school" today so they SHOULD help. They have been #$@@ poor so far. Only out to make $$. Thank God for Pool Forum.
Does anyone have any input on the motor itself ? Do you cover it ?
if outside, i would cover it, but with something that won't cause condensation and potential rust of any metal in/on the motor. for sure don't tight plastic wrap it. all you're really concerned about is moisture not getting into "dry" areas like the motor itself..i would probably use burlap if it's for snow protection?
