Thread: Lowering PH with Acid
    Dothan Alabama
    Default Re: Lowering PH with Acid
    Hardware store, Lowes, Home Depot all should have muriatic acid. I add it slowly in front of a return jet. Be careful with it - it's pretty nasty stuff.
    Jakebear is offline Registered+ Thread Analyst Jakebear 0
    Jul 2006
    Pennsylvania
    Not sure why but it's in the Paint Department at Lowes & HD.
    Yep --- it is nasty --- Also eats concrete (the lime I think)
    27038 Gallon InGround, Vinyl, DE filter.
    mas985's Avatar
    Pleasanton, CA
    Both Lowes and Home Depot in CA keep acid in the pool section. I think it depends on the area of country. In CA there are a lot of pools so it justifies having a separate pool section.
    Mark
