Thread: More test results
    p.p.h. is offline ** No working email address ** p.p.h. 0
    Dec 2005
    Phoenix, AZ, usa.
    Default More test results
    Here are my initial test results a few weeks ago after start up with my old test kit given to me by the builder. I dont know the company name of the drops.
    CH=275 CYA=80-90 FC=4.0 CC=0 PH= 7.4-7.5 ALK=140-150
    Water is 70 degrees
    New readings today with the old test kit
    PH 7.6 CL 4.0 (as far as the kit can test) TA 90 CYA 80 CH 275
    I bought a new test kit from Leslies. Its a DPD test kit using Taylor brand drops. Heres the readings
    PH 7.4 TA 120 Ch 300 FC 5.0 (as far as the kit goes) CC 0 TC 5.0+ CYA 80 CH 300
    Water temp 75
    Which kit should I trust ? Numbers look OK? The TA is way off between the 2 kits not sure which to trust at this point. SWC coming this week.
    Default Re: More test results
    I would re-test the TA using the new kit just to verify your first results, but I think I'd go with the new kit results. It's possible that your reagents have just gotten old in the older kit and are not giving you reliable results. The rest of the numbers are close enough that I wouldn't worry about them.
  1. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  2. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  3. First test results
    By poolbee in forum DPD-FAS based testing
    Last Post: 06-15-2006, 11:27 PM
  4. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 08:30 PM
  5. first test results
    By jazzbone in forum DPD-FAS based testing
    Last Post: 05-26-2006, 04:19 PM
