Re: pH not so stable after all - hTh kit
This has been discussed somewhere else on the forum. Basically the HTH kit doesn't neutralize the chlorine in your pool before you run the test so the reagent doesn't turn the correct color at a given pH. I've got the HTH kit and another off brand kit. The generic kit tests much higher pH in my pool because it includes Sodium Thiosulfate that you add to the water to neutralize the chlorine before you test.
22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
