tagprod
I have an aqualogic SWG with the goldline remote. Is the SWG working all the time when the pump is runing?
No. It will be based on the % setting you choose with a 120 minute cycle. So if it is set to 50%, it will be on for the first hour off the second and repeating.
Under the timers menu is a category called "Cleaner - All". Does this have to be set to initiate the cleaning process?
It should, depending on how it was set up. You usually set relays for manual or timed operation.
I've noticed when it is on the sheer descents turn on.
It could be that the display label is wrong. Labels are set up in the config menu.
I've got the SWG set to 55% but the chlorine levels have been a little low. around 1.0. Salt is at 3500 PPM. I think that's a little high, but the check system light does not come on.
How big is your pool? What is your CYA level? How long is your pump run time? All of these will affect the chlorine level.
