damn..i had an edit all written up and hit the wrong button..so, riddle me this:
- power level 1 extends cell life..i think i get that. why would i ever want to run it on any other power level..unless, my guess is a higher power level is required to maintain output level as the cell gets older, gets scaled, etc.
-is it a fairly safe correlation to say for example, that a power level 1 setting of 5 volts divided by power level 2 6.4 volts x the output setting in % (i.e. 50%) is an ok ballpark relationship to make. doing the math on this example, 50% on power level 2 is 40% of total available output on power level 1.
-is it easier on cell life then to run it at power level 1 and say 60% than it is to run it at power level 2 and 50%..(assuming those are fairly equivalent chlorine output levels resulting)
i had had it on power level 2, about 20% given my chlorine level was 3-4 ppm today..but i've now switched it to power 1 and 50%.
