Results 1 to 8 of 8
Thread: need to drain the pool
    tagprod is offline ** No working email address ** tagprod 0
    Default need to drain the pool
    My salt level is around 3600 to 3500. I need to drain the pool. there's a faucet directly above the pump and when I turn it on water comes out. I think I need to drain water below the skimmer line about a foot or so. Can I drain water without the pump on?
    Dothan Alabama
    Default Re: need to drain the pool
    If I'm understanding you correctly, no. Not unless the faucet is below the level of the water in the pool.
    duraleigh Guest
    If sentence #2 is because of sentence #1, you do not need to drain your pool.
    Do you have an SWG?
    Quote Originally Posted by duraleigh View Post
    Do you have an SWG?
    I do have a SWG. The remote base has a light that comes on that read "Check System". The SWG shuts down too. It also posts one of two things, salt level too high or cell temp is too high. I thought the only way to lower your salt in a pool was to drain and refill. I lowered the water level just to the level at the skimmers and am refilling with unsalted water. The perimeter of the pool is about 90'. I think if I add 3 inshes of water it should bring it down. A, I wrong here?
    Gainesville, FL
    Cool Re: need to drain the pool
    You should not have to drain down the pool because your salt is around 3500ppm. You may need to drain down the pool because the water is laping at the top of the pool deck.
    The hose bib above the pump is intended for the purpose of having to drain the pool. Connect your garden hose here and with the pump on, open the hose bib slowly.
    What brand of salt chlorinator do you have? How old is it? Post a picture.
    -Jeremy
    -Jeremy
    I fix broken pool equipment
    Florida Leisure Pool & Spa
    www.FLLeisure.com
    Gainesville, FL
    Member APSP
    Member FSPA
    APSP Tech I
    Quote Originally Posted by hinejs View Post
    -Jeremy
    It's an Aqua logic and it's brand new.
    duraleigh Guest
    Tag,
    Check with your SWG manufacturer. I think you'll find 3500 is possibly a little high but well within operating limits. I don't have an SWG so cannot comment accurately on what your issue really is but I don't think it's salt level.
    Gainesville, FL
    3500 is just a little bit high, but nothing I'd worry too much about. How many hours do you run the pumps, any idea what the gallonage is for your pool? Check system LED could also mean your cell needs to be inspected. Every 3 months, its a good idea to break the cell down and run a little water and muriatic acid and mix through to clean the plates.
    -Jeremy
    www.FLLeisure.com
    Gainesville, FL
    Member APSP
    Member FSPA
    APSP Tech I
