Re: Sand Filter Getting Air
I have pvc piped my pool last year to prevent leaks. I have went over every joint with pvc glue to make sure I didn't miss something. I do have a piece of heavy blue hose from the pump to the filter. I made sure that I used pipe threading compound on all to prevent leaks. When I backwash my pressure runs 20 psi. This is the usual pressure for my pool on filter also.
