Thread: Patching a small hole in fiberglass pool
    Jul 2006
    Default Patching a small hole in fiberglass pool
    I have an ingorund fibergl*** pool with a small hole (about the size of a shirt button). Want to get it taken care of BEFORE it grows into a problem.
    Any ideas on what I should use to patch it?
    Thanks....
    mbar's Avatar
    Ashland, PA
    Default Re: Patching a small hole in fibergl*** pool
    You can contact a fibergl*** pool company, they have stuff you can use while the water is in the pool. I had a gauge out of mine from workers dropping a rock in the pool, and it fixed it right up - can't even tell where it was fixed.
    Northeast PA
    Jul 2006
    How did you get a hole in your pool?
    Jul 2006
    Quote Originally Posted by [email protected] View Post
    not sure; could have been a weak area when installed, could have been worn from the sun. could hav ebeen hit by a pole skimmer...
    the hole is very small.....
