I fixed it but I thought I would post the answer in case anybody else should run into the same problem.
It was the timer inside the power supply that was causing the problem, so I simply byp***ed the timer and now run it with just the on/off switch. I may hook it up to an external timer
A free fix is the best kind, especially after 8 years :-)
It's always good to let all of us know how you fixed the problem, in case we need it in the future.
