Mine doesn't have that tube. Any way to tell if it's plugged?
It should not be it has that white cap on it and then goes right into the standpipe near the bottom.
Why what are your thoughts?
Nicole: 18' round AG with AstralPool Sand Filter and 1.5hp AstralPool Pump
Simply that if it got plugged then it would block the air flow.
I called Astral Pool today and they recommended silicone. I would rather do something permanent.
Matt 4X4 had some great ideas. I was also thinking about glueing on a piece of thick rubber to make up the gap, the same as electrical tape but hopefully with the glue permanent.
