Closed Thread
Results 1 to 10 of 22
Thread: What to do with solar cover
    Honesdale PA
    Default Re: What to do with solar cover
    Sounds like your idea will work fine. My pipe is about 15' because I roll the cover while in the pool for normal on and off thus the pipe has to be less than the width of the pool. At 16' the 2" pipe will sag so depending on your width you may want to go to 3". I don't think cold or freezing should hurt it. Before I store it I stand it on end and tie it to a deck rail so the wind doesn't get it. Sheets are to protect the bubbles from the straps and the 5 gal buckets on top keep the rain out. Two are in the pic, one is a cheapo that will get cut up for end pieces eventually.
    Attachment 550
    good point on the tube, maybe..my cover is 18 ft at widest point, 13 at narrowest (kidney) i have 5 of those tie down straps on hand with hooks on the end and adjustable cleats so i plan to use those to support...one about every 3 ft or so and i think even with 2 inch tube it should be fine, eh?
    Michigan
    We leave ours on the reel and cover it with a winter cover. We got one 2' longer than needed so we could completely close the reel inside the bag. All we do is make sure all the excess water has drained off, then remove the reel (with the cover rolled up on it) from the side reel holders and put it right inside the bag, zip it up and tie it closed on the ends. We leave it laying right next to the pool all winter. It works great, and we've never had any damage as a result of it being left outside.
    http://www.intheswim.com/Winter-Pool...Blanket-Covers
    Why BBB? Because money can't buy happiness, but saving it sure can!
    Here's how I store mine for the winter -
    I roll it up on the roller, then turn it half a rotation per day for about 1-2 weeks - this makes sure all water will eventually roll out of it.
    Then I just leave it "as is" on the posts where the roller is mounted with a long piece of plastic bungeed around it as a final protective layer.
    It's made from plastic and the winter will not hurt it, year 3 of doing this on a 3 yr cover that's on it's 4th year - still looks almost new.
    matt, doggie..you guys leave it outside over winter..i know you have snow, cold and humidity matt..what about you doggie? i considered leaving it on the roller and tarp cover the whole thing and bungie..that would definitely be simpler if the weather won't hurt it..mine is over 20 ft wide so no way i can store in the garage, but i do have lots of room to put it on the side in my yard.
    ps- i took a look at the cover and like the idea of it being completely enclosed with it, but i have exactly that plastic stand and i'd be concerned about the ends being open..i guess i could put a hefty bag around each end..maybe cheaper to buy a tarp, though
    roll it up and put it in a SPACE BAG
    Yes I am a newbie
    Grecian 17'x33' Vinyl liner pool
    ZeoBrite filteration
    SWG Aqua-rite
    Sta-Rite Dura-Glas 1.5hp pump.
    SAM Light
    21037.5 gallons
    margekendall Guest
    Thanks for all the help- all season- does anyone know if you can leave your solar cover under the winter cover? I was looking at a KEEPER KLEEN and it seems like the same thing. Thanks
    Michigan
    We live in West Michigan right near the lake. We get what they call 'lake effect' weather, so our winters are brutal.
    Does your reel tube come off the plastic ends tenax? Ours just pull right out, and that's why we can seal up the entire cover and reel tube (since we were smart enough to get the next size longer that is)
    if i take off a few screws off each end, yes, i can take them off..it's easy enough and i am concerned that the plastic of the reel ends will get brittle with winter temperatures..i guess i can follow the better safe than sorry philosophy and take em off.
Closed Thread
