Hello everyone,
I'm new to the forum and we inherited a 15,000 gal fiberglass pool with our house purchase last year. The pool has been great except for the fact that I cannot keep the pH anywhere near the 7.2-7.6 range I see recommended. I am worried about the heater failing due to the low pH readings I get.
The pool has a sand filter (6-7 years old and suspect for the low pH), heater, and I use tri-chlor tablets. I only "shock" the pool after pool parties which seems to be about monthly with Leslie's Fresh & Clear (potassium monopersulfate I believe) after pool parties. I used Calcium Hypochlorite last year but grew tired of the precipitant and the need to vac the pool after every "shock".
I keep planted aquariums and am very familiar with testing methods and know just enough chemistry to be dangerousAll of the below tests were ran with Lamotte kits (all in date) with the exception of pH and TDS tests which were run with a freshly calibrated Hanna meter (accurate to 0.01 pH) Here are the results of the tests I ran tonight:
pH - 6.66 @ 72.7F (7.2 with LaMotte Pool Kit)
TDS - 1127ppm @ 72.7F
TA - 116ppm
FC - 1ppm
TC - 1.5ppm
Total Hardness - 228ppm
Ca - 144ppm
Mg - 84ppm
The only test I don't have a kit for is CYA. I suppose I could get it tested at the pool store tomorrow but I don't put much trust in them![]()
Anyways, I'm open to suggestions as to how I can get my pH to keep from dropping. The sand filter will be changed out next spring unless I get recommendations to do it this fall.
I have went through nearly 80lbs of soda ash over the past two summers. I frequently add up to 4 lbs of soda ash to get anywhere from a 0.2 to 0.4 rise in pH but it is usually gone within a day or two. I know that volume of soda ash should raise the pH more, but it doesn't.
Just for an example, I had a pH of 7.0 this morning (LaMotte kit) so I added 2 lbs of Soda Ash. The pool filter ran all day (it runs 24/7 while the pool is open) and the pool sweep (Polaris 280) ran for about 2 hours after broadcasting the soda ash. I should have seen more than a 0.2 rise in pH after adding 2 lbs of Soda Ash!
Thanks and sorry for the lengthy first post but I wanted to give as much info as I could!
