I don't plan on using any other chlorine except bleach.
Why BBB? Because money can't buy happiness, but saving it sure can!
Thanks for the reply, Doggie! I thought that was the idea, but I just wanted to make sure!
Make sure that if you're leaving pucks or sticks in the chlorinator that you don't pour bleach directly in the skimmer...just in case there's a reaction.
18 X 40 IG Vinyl
3 1/2' ft to 8' deep
Pentair DE Filter
400K BTU Pentair Minimax heater
Mccato,
The ONLY reason to keep pucks in your chlorinator is if you have less than ~30 ppm CYA. If you are at 30 ppm or above you should remove them or at least do not add any more when they are gone. (NOTE: this DOES NOT apply if you have a SWG system). There are many posts on the subject but if my memory serves me correctly the CYA goes up proportionately with the chlorine addition but never goes away![]()
Thanks MaryLee and fcfrey - good advice. I appreciate the replies!
