Re: Will stabilizer lower PH?
It is not possible to tell how much the pH would drop by adding the acid unless you know the alkalinity of the pool. If you recall high school chemistry you may remember something about buffers - they tend to hold pH at their current level and its only when you exceed that level does the pH change. Thus, the higher the alkalinity the lesser impact you will have on the pH.
