Results 1 to 10 of 13
Thread: I need a pump lesson please
    Jul 2006
    Default I need a pump lesson please
    Besides price and warranty, what are the pros and cons of each? Is the NorthStar worth the extra money? How efficent are these diffrent pumps?
    NorthStar Pump by Hayward
    The NorthStar features a 1 year warranty on the pump housing and a 3 year warranty on the motor.
    NorthStar 1 1/2h.p. # Haysp4015ns 220v $429.95
    TriStar High Performance Pump
    Warranty?
    Hayward 1.5hp 115/230v EE TriStar Pump $394.95
    Hayward Super 2 pump
    Super2 has a 1 year warranty on the pump housing and a 2 year warranty on the motor.
    Super 2 Pump, 1 1/2 H.P. #SP-3015EEAZ 115/230 $399.95
    Hayward Super Pump
    The warranty is 1 year on the pump housing and 2 years on the motor.
    Super Pump 1 1/2 h.p. # SP2610X15 115/230 $322.95
    Hayward Max-Flo Inground Pool Pump
    Max-Flo 1 1/2 H.P. Pump #SP-2810X15 115/230 $249.95
    Jul 2006
    Default Re: I need a pump lesson please
    my pool specs (we start digging in 3 weeks)
    38k gals
    2" pipe
    Full rated vs max rated? humm
    mas985's Avatar
    Pleasanton, CA
    The easiest way to compare pump efficiencies is to look at each pump's head curve. You will notice that for a given head, the Northstar will have the highest flow of any of the pumps listed which also means the shortest run time for a given turnover. The extra money spent on the Northstar will probably pay for itself in the first year.
    Also, for an 8 hour turnover, you only need 80 GPM so 1 1/2 HP may be too much pump. 80 GPM for the Northstar is over 70 feet of head which is very unlikely if you are using at least 2" pipes.
    To learn more about pumps, head, turnover and other issues, I recommend this site as a primer.
    http://poolplaza.com/pool-pump-sizing-2.shtml
    http://www.poolplaza.com/pump-ratings.shtml
    Mark
    Poughquag, New York, USA.
    The Hayward SuperPump is very LOUD. I am replacing mine (only one year old! - you want to buy it??) with a super high efficiency Ikeric multi-speed pump. Very expensive to buy, but much cheaper to run and supposedly very quiet.
    The Ikeric is a rebuilt, rebranded Sta-rite Dura-Max II (I believe), so that pump might be quiet as well. Since you are already replacing a pump, I would consider the environmental apects.
    I would also recommend looking at a 2 speed pump. The price delta is small, but the cost savings can be substantial, and if you run your pump while you are swimming, low speed can be MUCH quieter.
    Sanford, FL
    I also have the Hayward Super 2 pump - but it doesn't seem noisy to me - maybe the sound is drowned out by the kids screaming and jumping in the pool .
    But seriously - I don't notice the noise at all.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    markphin is offline Registered+ Thread Analyst markphin 1 star
    a noisey pump may be because of a clogged impeller.
    Jul 2006
    Quote Originally Posted by mas985 View Post
    Mark:
    Thanks for the great info. The link above is perfect!!
    Where do you live? Your pool setup up is almost what I am getting?
    I live in the Phoenix area.
    THX again..
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by gordonhyde View Post
    Mark:
    THX again..
    I am in Northern California, SF bay area.
    Mark
