Results 1 to 10 of 13
Thread: I need a pump lesson please
    Poughquag, New York, USA.
    Default Re: I need a pump lesson please
    The Hayward SuperPump is very LOUD. I am replacing mine (only one year old! - you want to buy it??) with a super high efficiency Ikeric multi-speed pump. Very expensive to buy, but much cheaper to run and supposedly very quiet.
    The Ikeric is a rebuilt, rebranded Sta-rite Dura-Max II (I believe), so that pump might be quiet as well. Since you are already replacing a pump, I would consider the environmental apects.
    I would also recommend looking at a 2 speed pump. The price delta is small, but the cost savings can be substantial, and if you run your pump while you are swimming, low speed can be MUCH quieter.
    Sanford, FL
    I also have the Hayward Super 2 pump - but it doesn't seem noisy to me - maybe the sound is drowned out by the kids screaming and jumping in the pool .
    But seriously - I don't notice the noise at all.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    markphin is offline Registered+ Thread Analyst markphin 1 star
    a noisey pump may be because of a clogged impeller.
    Nope. Brand new pump, not clogged. It is fairly close to the pool and has been (relatively) noisy since day 1. I live in a very rural suburban neighborhood that is very quiet. We notice the noise primarily when NOT swimming.
    Like I said, I have the original Superpump, not the Superpump II, which may well be much quieter. The original is basically 15 year old technology, still sold today!
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by tphaggerty View Post
    What is your filter PSI reading? You mentioned that the pump is close to the pool so I would expect a low PSI reading and thus low head loss.
    One thing that can increase the noise of any pump is when the plumbing has very little head loss. The water flow is high so it tends to create more noise. For example, I notice this when my solar is on and pump noise is less.
    Mark
    I have solar as well. I will have to check the head loss.
    But, the Superpump (2 HP uprated) (again, this is not a Superpump 2, just a plain old Superpump) is just noisy, compared to many other pumps. The pump motor itself is whiny, with lots of harmonics, has been from day 1. The pump part doesn't really seem to make much noise. In any case, it is being replaced with a multi-speed motor. The Ikeric will run at low speed when the solar is not on, but kick up to a higher speed/higher pressure/higher flow when the solar kicks on in order to meet the higher head of the 2nd story solar. The Ikeric speed/head settings are adjustable, so they aren't actually set until everything is installed and running (unlike a regular 2 speed motor/pump, where high speed is normally something like 3300/rpm and low speed is 1650 hard set).
    Anyway, the Ikeric (1.5 HP full rated) is supposed to be close to inaudible running on low speed and much quieter than the "average" pump when running at high speed, plus it is supposed to be much more energy efficient all around. Not installed yet, so I can't confirm.
    mas985's Avatar
    Pleasanton, CA
    If you are so inclined, you should be able to run the solar on low speed as well after the panels are primed. Once the pipes are filled with water, the head loss going up is negated by the head gain going down. Most controllers will take care of this by running at high speed for a few minutes and the downshifting to low speed for the remander of the cycle.
    Mark
