Results 1 to 4 of 4
Thread: PPM ?? Set it to?
    Default PPM ?? Set it to?
    Today the PB's installed the SWG (aqua-rite).
    Just wanted to ask what I should set the PPM to? I am thinking 3600. What do you think?
    Yes I am a newbie
    Grecian 17'x33' Vinyl liner pool
    ZeoBrite filteration
    SWG Aqua-rite
    Sta-Rite Dura-Glas 1.5hp pump.
    SAM Light
    21037.5 gallons
    Dallas Texas
    Default Re: PPM ?? Set it to?
    Hi Mike,
    Go for a salt concentration of 3200 to start with. That gives you a little slop if you or your PB is a little too impatient in adding the salt. I have a 47,000 Gallon pool with both a AquaRite and an AquaLogic and have found that 3200 is perfectly adequate. My experence is that the salt concentration take a little bit to stabilize.
    47,000 Gal. Gunite, Irregular geometric shape with elevated spa
    Emerald Plaster!
    1 Aqua Logic PS8 w/SWCG
    1 Aqua Tech w/SWCG
    1 Pentair Platinum cleaner
    400,000 Hayward Heater
    Hayward Swimclear C5025 Cartridge Filter
    1 Swimmin' Lab, natch
    1 Swimmin' Boston Terrier
    Thanks a MILL!!
    I have yet to get home right now, but our PB called and said the SWG is in and adding salt at that time. Not for sure what it's set at, so that is why I ask and will change it once I arrive home tonight
    Yes I am a newbie
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
    Sanford, FL
    If you are referring to the setting of the SWCG - it will be in % - start with 50% and then adjust depending on your chlorine level.
    As far as the salt ppm - that is the amount of salt in the pool - I run mine at 3200ppm and 60% output (6-7 hours per day) to keep at FC at 4-5 with CYA of 40.
    Completed 8/21/06
    14,000 gallon 3'-6' concrete pool with Diamond Brite
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Hayward Super II Pump - Cartridge filter
    See pictures here http://www.philsimmons.com/family/ga...mages&keyword=
