Thread: Testing High Chlorine Levels
    Default Testing High Chlorine Levels
    I'm going to be closing my pool for the first time and (unfortunately) have a CYA level of 100. (A long weird story that I still can't figure out totally.)
    If I'm reading correctly I need to shock to 25 according to the "best guess chart", but my Leslies DPD Deluxe Test Kit only goes to 5. How do I test for the higher chlorine to make sure I've hit it with enough bleach?
    Thanks for the help!
    fcfrey is offline ** No working email address ** Thread Analyst fcfrey 0
    Central PA USA
    Default Re: Testing High Chlorine Levels
    Thelma,
    The only way to ACCURATELYtest high levels of chlorine is to use the FAS-DPD method. This can be tested with Ben's kit or using the K-1515-A test kit from Taylor ($30.00 with shipping).
    Since I didn't discover this site until it was too late, I bought all my test kits from Taylor direct here's the link: http://www.taylortechnologies.com/
    I get next day delivery since I'm close.
    A less accurate method is what is sometimes referred to as the shot gl*** method, take a shot of pool water and a shot (or 2) of distilled water and mix them then test. Multiply your test results by the total number of shots. THIS WILL GIVE YOU A SWAG (scientific wild @$$ guess) RESULT, but it is better than nothing if you don't have the proper kit.
    Good luck on your first closing ---- lots of good advise on this site!!!
    Thanks for your response.
    I have another question.........
    How much distilled and pool water is a shot? Is it the amount of water that goes into the testing vial?
  1. Testing for high chlorine levels
    By George in GA in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2012, 03:17 PM
  2. Testing Ph with high Cl' levels?
    By lstinthot in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-24-2012, 03:29 AM
  3. Testing high chlorine levels (without a good testkit)
    By Watermom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2010, 01:52 PM
  4. Testing high chlorine levels
    By psciotti in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-28-2006, 02:28 PM
