Janet's right--Bleach is high pH. Di-Chlor and Tri-Chlor are low pH.
Still, I keep the pump running for several hours after I pour in the bleach, so thousands of gallons are flushing it anyway--that's its job. So unless you are letting the stuff sit in there with the pump off, I don't believe it's an issue.
